Got roaming pass USA
0503
Got roaming pass USA.
I can’t get any data at all.  Everything set on phone.  Help please. I’ve done everything.
waiting call back from tech but not called.   Please help
1 ACCEPTED SOLUTION
Thanks. It’s just been sorted by ee. Something their eve.
Sent from my iPhone
_MrR_
Scholarly Contributor
Hey,
When you say you can't get data, do you mean you can't access roaming in the States (so you're there and your phone isn't picking up AT&T or T-Mobile) or is it a case you can't add the roaming pass (you're sending the short code or attempting to order via the MyEE app and getting an error)
Just to help understand the problem further so we can give better peer-to-peer advice
Sent from my iPhone
_MrR_
Perfect - enjoy the States (and the 5G on AT&T if your device is compatible)
