Gifting data
steve130
Hi- not been able to gift data for 2 days now- says it can’t view allowance right now but is trying to fix the issue. Irritating as I use these accounts Ed to move data around- there’s plenty there. Anyone got a fix? It’s happened before then magically resolved. Did usual restart/ plane mode/ this is online not the app.
Rach_H
Hi @steve130
Welcome to the Community!
We want to make sure you can gift data to the other lines on your account whenever you need to, so I'd love to help you with this.
Are you able to try using the app, and see if you have any luck doing so?
Rach
Hi- yes app worked- rather have not downloaded it due to space- should work on both platforms really and has been an issue for many over years.
it’s working though that’s life
Rach_H
It's great to hear that this is now working for you @steve130 and it sounds like it isn't an issue with your account.
Can you try clearing the cookies and cache on your browser, and see if this lets you do this?
Rach
