Essential SIM Unlimited £28
TT1111
Hi Does anyone know does this sim have limited download speeds. Thanks
Profile closed
Not applicable
Hi @TT1111
Welcome to the EE Community,
The plan has a max speed of 100 Mbps.
David
8 REPLIES 8
Profile closed
Not applicable
Hi @TT1111
David
garetc
Scholarly Contributor
It has a speed limit as per the below
Excellent speeds, max. 100 Mbps
The max speed plan is £31
Thankyou
Thankyou
I say's on my Plan = Our best speeds No max mbps, I should have ordered the £31 sim.
Profile closed
Not applicable
@TT1111 if you call customer services on 150 they will be able to change your plan to the £31 plan if you wish to change it.
@TT1111 wrote-  I say's on my Plan = Our best speeds No max mbps
That suggests that the Plans DL Data Speed is already Uncapped.
New Plans normally say -
  • Excellent speeds, max. 100 Mbps (Capped)
  • Our best speeds, no max. Mbps (Uncapped)
Have you done a Speed Test?
Hi, it's a really bad signal area where it's for, have an antena fitted and could get most of what I wanted but couldn't get the cctv cameras to play, speed test was only 30 Mbps download can't remember upload but was less.  As you can tell I've not much of a clue, it's a lot better than I had which was nothing. I'm not sure it would make a difference just trying different things and trying to knock them off the list. Thanks
Thanks, I was too late last night, going to give them a call
