Data usage abroad
Hjb3
I have unlimited data but I went to Portugal and my data wouldn’t work. I’m going to Czech Republic so I need it to work. How do I use my data abroad
Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
