Data has disappeared
Kaidiac1980
I have a 10gb data plan, which renewed on 11th.
Its now 10 days into month and data has all been used. Checked usage and it shows a sudden jump of about 9gb used in last 24 hours.
However when I check my apps highest usage since renewal date (i.e 11th) is only 350mb on any one app, and all apps in total look to be <1gb
So where the heck has the rest of my data gone???
James_B
EE Community Manager
Hi @Kaidiac1980,
Do you share data with other devices via your hotspot?
I do occasionally, but I haven't done so in the period when my data disappeared
James_B
Hi @Kaidiac1980,
Our Technical Support Team will be happy to take a detailed look at your usage if you get in touch on 150.
