on 01-06-2025 04:28 PM
I am looking at upgrading my Sim only deal for my phone. I also have a Samsung Galaxy Watch 5 (bluetooth) (SM-R910). Would I be able to utilise the watch data plan?
Solved! Go to Solution.
on 01-06-2025 04:56 PM
Hello @Benbailey1109 ,
Welcome to the community,
If your watch is bluetooth only and is not cellular, then you will have to use bluetooth when out and about as you will need your phone with you, at home, you should be able to also connect to wifi, only cellular watches will work on its own data plan, which you have to pay for it, monthly.
