24-09-2025 10:43 AM
Each month I am running out of data!
I get a message to say I’ve used 80% of data allowance… I can’t work out how!
I’m on WiFi most of the time (I think) and have been turning off cellular when I leave the house…. This all feels pointless to have a phone I can’t use when I need it out the house!!!
I’ve checked my apps and other to have much open….
any thoughts?
24-09-2025 10:46 AM
Android & Apple phones have a data counter facility that itemises data usage app-by-app, and in the case of Android, also separates WiFI & mobile-data. You can also synch the counting period to match your EE billing cycle.
Use of this menu option often helps in the case of "what's used my data" queries.
25-09-2025 01:03 PM
I am getting exactly the same thing. I am only a few days into my plan and the data has gone! This has started happening in the last couple of months … any help on what is causing it would be greatly appreciated too!
25-09-2025 01:21 PM
Even tho you’re on WiFi you’re still using mobile data as well it has to be turned off as it runs on both not one or the other so when I’m in the house or connected to a WiFi I turn the mobile data off and when out and about have it on
25-09-2025 01:23 PM - edited 25-09-2025 01:25 PM
@Poysert wrote:I am getting exactly the same thing.
Then follow the exact same advice as posted above, What does your data counter say?
@Nicola90 wrote:Even tho you’re on WiFi you’re still using mobile data as well it has to be turned off as it runs on both
Your phone will use one data connection at a given time. WiFi will take preference when available, unless a specific individual app is configured otherwise.
25-09-2025 01:32 PM
25-09-2025 01:42 PM
@Poysert wrote:
My data counter isn’t set for the period
Once you've changed the data counting period, you can use the facility to identify the cause of your increased data usage.
