smart 4g hub
Lb28000
I received my smart 4g re hub yesterday it’s working absolutely fine for phones other devices but won’t connect to my sky tv. What do I do? Because if it don’t connect to that I may aswell by a tablet and an unlimited sim because it works absolutely fine for mobile hotspot.
Alex_H
Hello @Lb28000,
Welcome to the EE Community
Other 4G broadband customers who have reported issues connecting to Sky TV have suggested moving to an IPV4 profile in your router settings helps fix it.
You can do this by logging into the router admin page by loading 192.168.1.1 in your browser, the admin password will be located on the back/bottom of the router or on the keep me card that came with it.
Once there go to Settings> Setup> Profile management and click to create a new profile. All the details are the same as the current profile except change the IP type to IPV4 then save and set as the new default profile.
Give that a try and see if that helps with connecting to your Sky TV.
Alex
Unfortunately that hasn’t worked either it doesn’t even allow Netflix to open
