14-09-2022 02:45 PM
i purchased a 2nd hand hub and got a 120 gb sim from argos, set up hub, and it works but the app wont let me log on after logging in says something went wrong please try later, i have tried uninstalling and reinstalling but still the same.was asked to try desktop site, ee site seems to go to register palge and i put in phone number then says
to finish setting up your account
@ links to members
14-09-2022 04:28 PM
MyEE doesn't work for registering PAYG MBB devices or at least those with data SIMs. It stops at telling you to connect your device & login to it, but when you've done as instructed it doesn't have anywhere for you to say you've done it.
You may continue using your device but you just can't register it to MyEE.
These should still work.
