does anyone know the best mobile wifi router as were gonna be living on a boat
paulisa123
6 REPLIES 6
@paulisa123   Are you looking at purchasing this from EE ?
Northerner
Hi @paulisa123
Living on a boat at sea. Abroad, canal?
If in the UK they should all work subject to coverage.
@paulisa123 : The Netgear Nighthawk is well thought of.
EssexBoyEE
What kind of Boat?, Ocean Going, Fibre / Resin, Yacht, Narrow Boat, Steel?
Location?, permanently Moored, Marina or Harboured, River Cruising, Off Shore Coast ?
Ive installed quiet a few 4/5G Systems in Water Vessels and depending on type and usage (and Budget) and if done properly, most of them normally end up using External LTE Antennas, Split or Outdoor Routers, separate WiFi Routers and some specialist Cabling.
What’s the best mobile Wi-Fi unit for a motorhome? We’ve got a satellite dish, but want to use a fire stick as well, thanks
Christopher_G
Hi @Crich
You can browse our current range of Mobile Broadband devices here. I know you're looking for recommendations, so hopefully someone will be along to share their experience soon.
