code 403 forbidden
maggi5
Hi, I am trying to place an add on on my mobile broadband data but it comes up with error 403 forbidden. any ideas to clear it
thanks
James_B
EE Community Manager
Hi @maggi5,
Have you tried clearing your cookies and cache in your web browser to see if that helps?
Hi yes I've tried that but still have the problem.thanks
James_B
Hi @maggi5,
Which link are you using?
Wasteof7im3
I am having the same problem and it doesn't matter which buy add on I use it comes up forbidden. I have tried using Edge and Chrome and clearing cache but it doesn't make a difference.
I have the app on my phone but that simply wants me turn off wifi but since I am trying to buy an add on for another device that doesn't work either.
All in all this is very frustrating and the various help docs and advice simply don't work.
@Wasteof7im3 : Look at http://add-on.ee.co.uk/purchase from a device connected to your mobile router by WiFi to see what data add-ons are available. Make sure you use HTTP:, not HTTPS: & do it under IE, FF or Samsung Internet not Chrome.
