07-12-2023 06:28 PM
local external signal does not work in my house, so phone linked to modem signal, but some rooms are too remote for that signal. I used ethernet to connect to my PC, where I most want to use my phone. Is there a devise I can fit to the end of an ethernet cable to generate a local signal I could pick up on the phone.
07-12-2023 06:55 PM
@Bernard998 you could fit a wifi extender of your choice to your cable, and prifiding your phone supports wifi calling that should meet your needs.
07-12-2023 06:55 PM
