Unlimited Data Addon
Piggeries1
I have just bought unlimited Addon but it doesn't make clear is it's 500MB per month or not.
I can buy GB data only SIM cards from Amazon or eBay for a lot less, so why is it more expensive via EE than elsewhere?
9 REPLIES 9
@Piggeries1  if it’s an unlimited add on then it’s per month.  An unlimited add on can not be limited to 500Mg per month as that wouldn’t be unlimited.
Hello, thank you for your help. This is what's confusing me.
" Unlimited Data Add-On ( 30 Day )
Pay as you go Add-On 500MB UK data, 3G and 4G double speed for 7 days "
Leanne_T
Hi @Piggeries1
Is this information showing in your My EE account?
Does this include your included data allowance for the pack/plan that you have?
Hello, this is what it says when you click Get  more Add-ons UK EU Data - Unlimited Data Add-on ( 30 Day ) £40 monthly. Click that and the message says "
500MB is nothing, very expensive for so little when on Amazon or eBay data only SIM cards are bigger and cheaper
Leanne_T
That is giving you two options to purchase I believe @Piggeries1
Do they have two different charges?
Not 2 options only to pay £40, which I did. I'm looking to cancel after 2 days as 500MB is nothing per month. I tried to update some software and it would have used nearly all that data. So couldn't update. I'm thinking of buying from Amazon instead as they offer GB data Sims for cheaper that £40 per month
Leanne_T
Hi @Piggeries1
Please call us on 150 and the team will get this looked into for you.
Leanne 🙂
Hello Chris how would i add 4g unlimited per month without calling you guys any option online i Couldn't find it :?(
James_B
EE Community Manager
Hi @perchwane,
You can view all of the data add-ons available for your plan at add-on.ee.co.uk.
Hope this helps.
