on 25-06-2022 06:52 PM
Hi I have two ring stick up cameras having difficulty connecting to ee 4g home hub
Solved! Go to Solution.
on 25-06-2022 06:57 PM
Are you connecting to the 2.4 GHz SSID?
on 25-06-2022 07:03 PM
Hi yes I am on 2.4
on 26-06-2022 09:14 AM
Hi @Droseveare.
Have these cameras worked before on another form of broadband?
Is your 4G Home Hub working with other devices?
Jon
on 26-06-2022 11:29 AM
Hi worked perfectly on bt 4g hub problem started when I switched to ee
on 26-06-2022 11:38 AM
Hi all other devices work fine
on 26-06-2022 11:39 AM
Yes tried them on my neighbour’s network works fine
on 26-06-2022 11:42 AM
I think the problem is ipv6
on 26-06-2022 01:49 PM
@Droseveare : I doubt that IPv6 is stopping devices in your home connecting to the router. It more affects access to external websites.
However, just in case it is an EE IPv6 issue, can you change the Profile/APN on your EE device to APN Protocol = IPv4 only? Or play around with that setting.
