Passwords
alfiemalfie
Where do I find the password for my EE dongle? I've lost the paperwork that came with it, which included the password.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
alfiemalfie
Ignore the question, I found it!
