Nighthawk M1 Router Problem
StevieBambs
I have a preloaded EE, which was working in my Nighthawk M1 but now shows 'mobile broadband disconnected' & shows the letter E where used to show 4G signal ?
@StevieBambs : You mean a preloaded SIM?
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
What does http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi say about your data & credit status?
Contacted EE technical & found that the sim had been suspended due to period since last use, has been reactivated & working fine now.
Technical were very helpful & sorted quite quickly.
Leanne_T
Thanks for coming back and letting us know @StevieBambs
