Mini Mobile Wi-Fi box 120gb does this keep working indefinitely until used up?
Suki29
Will this data last until i have used it up or is there a time limit on how long it will last? Bought it last august still got 80 gb left. Hoping it lasts as long as there is still data on the sim inside it. Does anyone know?
thanks
It's usually a year but this should tell you ...
Look at http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see data & credit status.
Thank you for this info, great help as had problem checking data left.  Maybe you'd be able to help with another question....can I add my mini wifi to my ee account, if so, how??
Katie_B
Hello @Joew90_
Is your WiFi mini under the same billing account as your mobile?
Katie
Bought it preloaded...but was asking if I could add to my contract because only got 14.4 left
Sent from Outlook for Android<>
You can't add a PAYG no. to a contract MyEE a/c. They don't mix. You would need to set up a separate MyEE for it. Anyway you can't gift data to a PAYG no.
