I desperately need help with activating a new pre paid sim please🙏
Steve1737
I have bought an EE 120gb data sim for my rut950 4g router. I have put the sim into the router but nothing is happening. I can't put the sim into my phone as it is a different size. Please help as I have read that the sim will need to be activated by EE before I can use any data
Michael_D
Hi @Steve1737
Welcome to the community.
It would need to be put into a phone to get it up and running. If you look at the SIM, it should be a multi SIM, which pops out the size of the SIM that is needed, and can then be put back into the larger SIM.
Are you able to try that?
Michael
7 REPLIES 7
Michael_D
Hi @Steve1737
Michael
I'll give this a try. Thank you🙏
Sent from Outlook for Android<>
Michael_D
My pleasure @Steve1737.
Please keep me posted with how it goes.
Michael
Hi Michael, I think it's worked but I can't find any EE wifi from the router🤷‍♂️. I did a speed test and it came back as 11mbps which I've never had before. I think it must be under the router name maybe🤔
Michael_D
You would need to look for the router name itself @Steve1737. The SIM just gives the data connection to the network.
Michael
Thank you, it's working then🙏
Michael_D
Brilliant news. Thanks for the update @Steve1737.
Take care and have a great day 🙂
Michael
