Historic Monthly Data Useage
Rickwallis
I have a MiFi box that I use to watch my Firestick when I’m our caravan.
I have a 100GB per month SIM.
how can I check how much data I have used per month in the past? I may be able to save some money by buying a plan with a lower amount of data per month, but don’t want to run out of data half way through a film!
Peter_W
Hey there @Rickwallis
Welcome to the EE Community 😊
Is it a pay monthly account that you have for your mobile WiFi SIM?
If it is, you can log into your account and check the amount of data you've used for the last three months.
From the home screen just select Plans & Subscriptions > Manage Mobile > See all usage > Usage history, and this should give you a breakdown.
Peter
