12-11-2022 09:06 PM
Hello.
I have a HH70VB white 4GEE router which won't boot. All the lights come on, then go off one by one until only the power light is on.
I've tried to do a factory reset, but pushing the reset button doesn't do anything.
If I 'ping' the router from cmd, I get a reply from the router so its not totally dead.
I've tried contacting support, but they weren't able to help. Any help would be much appreciated.
12-11-2022 09:17 PM
That's normal to preserve the battery. Check its Connection Status by logging into it &/or seeing that it's broadcasting its SSID.
12-11-2022 09:34 PM
Hello.
It's a mains powered unit. I can't login to it via the browser (page cannot be displayed after a few minutes) and it's not transmitting it's SSID. I've left the unit it on for an hour in case it was stuck in a boot loop.
I've found an Alcatel HH70VB image online, so might give that a go if all else fails but have since seen that the old backdoor into the router has been removed 😔
12-11-2022 11:32 PM
Try this -
Power off Device.
Whilst off, push in the Reset Button and keep it firmly pushed in during the whole process, as follows, Power back on, wait at least 1 min then release Reset Button.
