25-11-2023 05:28 PM
Can some one assist ?
I forgotten My yellow block Mobile WiFi Password
What do I do ?
25-11-2023 05:59 PM
@57frsmjp : Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
