External antenna for 4G mobile router
TMTR
Whilst the EE 4G network is now providing consistently poorer speeds outdoors which is then being reduced further by the router being indoors, I would be willing to try and improve things a bit by buying an external antenna if that would help.
I note many threads on this topic, all with helpful advice but none with a definite answer.
I have the following EE-supplied router (not sure who it is manufactured by). This is the spec:
Device name
4GEE Router
Serial number
[mod edit: please do not post personal information such as phone numbers on the public board. Thanks!]
IMEI
My number
Hardware version
WL1B625M01
Software version
10.0.5.2(H200SP5C1055)
Web UI version
WEBUI 10.0.5.2(W2SP2C1055)
LAN MAC address
CELL_ID
4836609
RSRQ
-5.0dB
RSRP
-76dBm
SINR
14dB
PLMN
23430
Is there an external aerial available for purchase from EE or a third party please?
Leanne_T
Hi @TMTR
Thanks for coming here.
I would suggest getting in touch with our technical support team to discuss your options and see what is available.
OK - will do - so long as I don't have to spend an hour going through the standard questionnaire first, (and every time I ring) 😉
