on 31-08-2023 06:43 PM
So I've bought the EE71 and would really like to use it with a TPLink extender to connect a hard wire RJ6 device. No WPS button on the EE71 though to connect the two. Is there anyway I can get the TPLink to read the EE71 signal ?
Thanks !
Solved! Go to Solution.
on 31-08-2023 06:50 PM
@SRAPUBLIC have you tried using using the TP link Tether app
on 31-08-2023 08:27 PM
Yes I did. It occurred to me straight after I posted. All sorted now. Thanks.
