EE Mobile 4G range extender
Dickie54
Does EE have a 4G mobile Wi-Fi extender? I’ve tried using other extenders and they crash the modem or drop out repeatedly. EE said they were planning to sort one. Have they done it? Thanks.
Christopher_G
Hi @Dickie54
Welcome to the community.
So are you trying to use an extender with a 4G WiFi device? Or is it like a booster to get better indoor mobile coverage?
Thanks Chris.
I’ve got an EE Mobile 4G router in my house, with an external aerial to boost the signal. Unfortunately due to brick internal walls etc the Wi-Fi signal from the router does not reach the whole house. I’ve tried various range extenders. I would like to use one which transmits the signal through the house electrical wiring. I’ve tried a couple of different ones in the past but they seemed to crash the router so it needed to be reset.
EE couldn’t advise what to do. They said they were planning to produce one which would work and that they would supply. I was trying to find out whether they had done so.
Richard Stein
XXXXX XXXXXX
XXXXXXXXXX
[Mod Edit: Removed telephone numbers]
Christopher_G
I'm not aware of any 4G extenders that would help in this case, @Dickie54.
Hopefully another user can come along with some recommendations.
Dickie54
Does anyone out there have any ideas to help with this?
