Access sms on smart hub
Hugo-2022
@LS541 : Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover or on a label & look at the SMS Inbox
Mustrum
@Hugo-2022   can you let us know a bit more?
What is it you are trying to do?
Hugo-2022
Hi on the top of smart hub is a row of 5 lights one of which is a green envelope and I've looked at what the lights mean and this envelope silhouette means I have sms messages to read, but I don't know how to access?
@Hugo-2022 : Which mobile router do you have? A Smart Hub is a fixed BB router which doesn't have 5 lights one of which is a green envelope.
Usually login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover or on a label & look at the SMS Inbox
My new 4G Hub- WIFI  with a sim is flashing green- which I’m told means I have messages but I can fin these online when I logon
