31-05-2023 08:22 AM
Hi
I have a 5gee router and it’s fine but i am moving into the countryside where there is a poor EE signal I don’t want to pay for another provider so I am looking for a solution? Any help will be much appreciated.
31-05-2023 08:27 AM
@Napper You might need to get an external antenna for your device if you don’t already have one.
02-06-2023 05:33 PM
Ok where do I get a 4g aerial ?
03-06-2023 07:47 AM
Hi @Napper
If you contact our technical support team, they'll be able to run through your options with you.
