22-12-2021 12:18 AM
I try to connect blink camera to 5GEE mobile router
Camera still says maybe wrong password. I tested cameras on my 2 other routers and it all works OK. What setting should I change more?
22-12-2021 08:12 AM - edited 22-12-2021 08:12 AM
Hi @awariat
Welcome to the community.
I'm not sure what could be the problem. Which password is it asking for?
Were they 4G/5G routers that you set it up successfully on?
22-12-2021 11:10 AM
Thank you
The requirements for blink camera are
2.4 GHz and 'n' Wi-Fi. My 5Gee router works and I can connect to it except with blink camera. I removed 5GHZ and even set 4g for router and still doesn't connect to blink cameras. Any ideas what can I do more. I bought this router for cameras. All my blink cameras works on other 2 routers I have. I don't want to buy another router. Any ideas what Can I change in settings to make it connect
22-12-2021 03:30 PM
Hopefully another user who has tried to set them up on EE in the past comes along, @awariat.
I'm not sure what else you could try. Have you tried speaking with the manufacturer?
24-04-2022 01:30 PM
It works but its not Stong enough for the cameras and wont let u load up
01-06-2022 07:31 PM
Hi sorry to tag on to this. But mother-in-law tried setting up blink camera to 4g mini wifi device which apparently can support upto 64 devices. Same problem, when trying to view live feed from the camera, no bueno. Set same camera up on wifi at home. No problems at all. No issue with 4g signal. Its like the router itself isnt beefy enough. Are there any advance features we can tweak? So far changing the wifi channel didnt work.
02-06-2022 05:35 PM
Hi there @Stu101
Thanks for coming here.
I would suggest getting in touch with our Tech Gurus on 0800 079 8586 and they will get this looked into further for you.
Thanks 🙂
