5G data sim activation
ianhp
I have purchased a 5G data sim, and have installed it to the 5G router. I have full wireless coverage, and the router is showing both 4G and 5G 'signal'.
However there is no internet connection. I assume I have to activate the sim, but as its in a router I can't receive a one-time PIN.
How do I activate the sim without a phone?
Northerner
Hi @ianhp
If you go into the settings there should be a text message option. There normally is on these routers.
@ianhp : Does your mobile router have an envelope LED? That means it does do SMS.
Really you should not need to activate the SIM. Is it on contract or PAYG?
Aliahmad9900
5g sigal is not show
James_B
EE Community Manager
Hi @Aliahmad9900,
Are you in a 5G area
Is your device 5G ready?
Are you using a pay as you go or pay monthly plan?
