on 05-02-2023 01:55 PM
Got a 4GEE WiFi mini today. Do I need to register the SIM? And can I change the number to an name so I can find it in my settings when go into WiFi settings .ta
05-02-2023 02:02 PM - edited 05-02-2023 02:07 PM
@grahamdavey5 : You can try to register it to your MyEE but it's not essential.
You may use your device w/out registering it to MyEE.
You can't change its mobile no. to a name within the router's settings. You may however change its WiFi network's SSID to anything you like so you may recognise it from your devices, if that's what you are thinking of.
on 05-02-2023 02:08 PM
Thank you for your reply and yes that is what I am thinking. How do I do that as not sure 😊
on 05-02-2023 02:12 PM
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi SSID & password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi SSID & password in clear & change them if you like.
on 05-02-2023 02:26 PM
Thanks will give it a go just waiting for it to charge as guess needs to be on for me to do anything 🙂
05-02-2023 02:31 PM - edited 05-02-2023 02:32 PM
You should still be able to use it while it is on charge over USB. You may certainly access its settings.
on 05-02-2023 03:07 PM
Ok so changed password but no idea how to change SSID? Any ideas in settings how I do it or where in settings? Sorry
on 05-02-2023 03:13 PM
Isn't it above/next to pwd?
on 05-02-2023 03:44 PM
Thank you for your help all sorted now 🙂 I think
on 05-02-2023 04:31 PM
