orange pension scheme
Caroline142
Good afternoon.
I worked for Orange PCS Ltd in London between 2004-2006.  I am trying to trace a pension administrator (the phone number on a letter many years ago is not working).  Does anyone have an email (preferably) or phone number and details of how I can trace my pension please?  Thanks.
Alex_H
Hi @Caroline142,
I have sent you a private message with the details you need to help locate your pension.
Alex
24 REPLIES 24
Alex_H
Hi @Caroline142,
Alex
Hi Alex,
I have a similar question. I was an Orange Employee from 2008 and with BT until 2022. I have found my original EE Pension scheme, but can you confirm if the Orange Pension scheme evolved into the EE Pension scheme?
thanks
Mitch
Hi Alex
Thanks for the reply and I have called using that number but there are so many options to press.  Did Orange get taken over by BT in the end and this now falls under BT?  Can you give me an email perhaps?  Regards
Alex_H
Hi @Mitchjpm86,
Welcome to the EE Community
I have sent you a private message to help get you an answer to your pension question.
Alex
Alex_H
@Caroline142 That is correct yes Orange was part of EE which is owned by the BT Group, so its all the same company. Option 7 should be for Pensions then if you are unsure of the next one just select option 1 to get through to someone to assist you.
Alex
Gdes1986
Hey Alex could I have that info too please I used to work for orange retail and can not remember any details of the pension
Ali_A
Hi @Gdes1986
I'd like to get you some help with this.
I'll send you private message. Please check your inbox and get back to me when you can.
Ali
Hi, I worked for Orange PCS from 1999-2001 and am struggling to track down my pension fund.  Government pensions tracing website says its administered by Towers Watson but they deny having any record.  PLease advise
