on 11-02-2024 02:56 PM
I'd like to add Wi-Fi Enhancer for Game Mode, assuming it's worth it. I can't find how to add it with online or in the app anywhere. Can find loads marketing info about it though.
Does anyone know if it benefits over ethernet connection?
on 11-02-2024 04:36 PM
Which EE BB plan do you have? Is it New EE BB?
on 11-02-2024 11:09 PM
Hi, yes it’s new EE Broadband 500mbps
on 11-02-2024 11:31 PM
It should be found in your EE app under Manage WiFi Controls.
By its name I can't see it benefiting Ethernet.
on 12-02-2024 11:06 AM
on 12-02-2024 05:50 PM
Ok, thanks both for your replies. I cannot se with under WiFi controls or anywhere else in the app. I understood it to be an add on, but cannot see that either.
