WiFi poor
Simonconka
I am just leaving a message here to ask as I have moved from Virgin to EE and I have the booster too and my WiFi is so weak while I have meetings or in study classes it load or disconnect me any advice in here what I can do as this is getting on my nerves now
@Simonconka   Do you need the booster?  These can cause issues if it’s not really required.
How far away from the router is the booster and are you in the same room as the booster.
 It’s not really a booster is it doesn’t boost the signal and make it stronger, it’s so the WiFi signal can reach further within your home.  It’s a repeater, it’s just another access point.     You might find that the repeater isn’t close enough to the router so that in itself isn’t getting a good connection to the router.   But just to check you are connected to the repeater and not to the router with the device you are using?
also is the router close to any other electronic device?
Maestro
Maestro
@Simonconka If still within your 14 days of going active on the EE system, then you can also go back to VM for your broadband as well, see the link below just in case you have it all wrong your end. If using an EE supplied booster make sure it is the correct one to go with the correct EE Hub bottom link, the Forum has no idea what you have or what you are doing.
 https://ee.co.uk/help/broadband/manage-use/manage-your-ee-hub
https://ee.co.uk/help/broadband/fix-problem
BB issues are rarely widespread but specific to your own line.
If it is a neighbourhood issue, you could consult Check service in your area  to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
Which EE router & WiFi extenders, if any, do you have (read label or post a pix)? What is the name of the EE BB plan are you on including its speed?
