29-07-2026 01:39 PM
Can't login to the EE app, I can login here and on the website but whenever I try to login to the app it sends me in a loop. I've reset my password, cleared the cache, uninstalled and reinstalled but no fix.
Its irritating because I need to obtain my eSIM which I can't because I can't get into the app, it's irritating. Contacted EE they said it can take 24 hours to initialise the SIM but no reasoning as to why I can't get into the app. Any help or? Thanks
29-07-2026 04:14 PM
Hi @R932,
Welcome to the EE Community
Sorry to hear you are having an issue logging into the app. When you say it is getting stuck, what is the loop that the EE app is getting caught in exactly, what happens?
Alex
29-07-2026 04:19 PM
29-07-2026 05:19 PM
@R932 Thanks for clarifying, I have been able to try a full re-install and was able to get setup without any issue, after confirming the PIN sent via text it should take you to a setup a login PIN page and then biometrics etc.
In between the uninstall and re-install have you restarted the phone? Do you have any other phones/devices around you could try logging in to the app on to confirm if its just affecting your phone or not.
Alex
