I cannot make outgoing calls as the phone seems permanently engaged
Oliphant97
I cannot make calls out as mybphone seems permentnly engaged but can receive incoming calls. Advice, please?
Schockwave
Hello @Oliphant97 ,
Welcome to the community,
Have you tried rebooting your phone? Never heard that one, if you can receive calls then you should in theory be able to make calls. Have just read it is a digital home phone, where have you plugged your phone, which socket and is it plugged in correctly in the router, which I believe it should be?
Storm500
Expert Contributor
Expert Contributor
@Oliphant97  You say you can’t make outgoing calls but have you tried dialing a number? The Digital Home Phone’s voicemail signal that you have a message is a tone similar to the engaged tone. Dial 1571 to see if you have any messages.
