Handsets constantly having to synchronise
Neil8568
Valued Contributor
Valued Contributor
I fairly recently moved from BT to EE. There have been issues with my digital handsets ever since and it just seems to be getting worse. They will randomly drop out and become unusable whilst they synchronise again and again.
Leanne_T
Thanks for coming back to me and apologies this was missed @ISPY
If everything is showing connected OK, please give us a call and our tech guides can run through some troubleshooting with you to see what could be causing this 🙂
13 REPLIES 13
Leanne_T
Morning @Neil8568
Does this happen on incoming and outgoing calls?
Are there any changes to the router lights when the calls drop?
Speak soon 🙂
Maestro
Maestro
@Neil8568 How long has this latest issue for syncing been happening?
ISPY
Im having excatly the same, phone rings I pick it up and just get musical tone and message on screen saying synchronissing handset data. 3 times in 14 hours, always the same 0845 number.
Leanne_T
Morning @ISPY
Thanks for coming to the community 🙂
Does this happen when the 0845 number calls you or when you try and make a call to this number?
Which model phone are you using?
Speak to you soon.
Hello, As I stated in my post, it's an incoming call from 0845. My base is Firmware 413 and Handset Firmware V3.0 BT_025 checked Hub settings and both handsets are registered ok
Sent from Outlook for Android<>
Leanne_T
Neil8568
Valued Contributor
Valued Contributor
Still having the same problem. Works for a few days then it is back. Can happen for both incoming and outgoing calls. Screen goes blank , then the bt logo appears with a little tune and back to synchronising handsets. No apparent change in hub when happening
@Neil8568 Has been reported on the Forum that losing and having to repair the handset's have been put down to bad rechargeable batteries in the handset's, you may wish to get a new set or swap about another handset if you have to see how that goes.
Neil8568
Valued Contributor
Valued Contributor
Hi. This has been happening again at an increasing frequency and my landline is almost unusable. I would either like a definite fix for this or advice on how I cancel my landline subscription as its pointless having one
