01-07-2025 02:03 PM
01-07-2025 02:09 PM
Which is what? Please clearly explain your issue & circumstances in greater detail & we'll do our best to help you with it.
01-07-2025 02:29 PM
My Landline is stuck on the voicemail symbol. I cannot check for any messages and also cannot ring 1571, as it just cuts off.
01-07-2025 04:12 PM
Hi @Bob682
Have you tried restarting your router? Or if needed resetting it?
Ali
01-07-2025 06:45 PM
@Bob682 If you reset the Router YOU will lose all off the contact information that you have put in! So be aware!!!!
