Contacts list
Stee12
If I turn my router off for a short while will I lose my contacts list?
Maestro
Maestro
@Stee12 What router do you have, normally it takes a factory reset to clear out the contact list, so off for a short period should have no effect on contacts.
It is an Ee hub with digital phones.
Maestro
Maestro
@Stee12 You should be good, phone stores zero about the contact list, they are all stored on the EE Router, so as long as you do not factory reset the router then all should be fine.
