call charges
ccapybaraa
hi. i’m not rly sure if i’m doing this right but im just wondering if anyone could tell me whether or not it is free to call 0300 numbers? i need to make a call to an 0300 number (the phone first service for ni hospitals specifically) and i want to know how much it will cost me, especially hearing there can often be long periods of being left on hold etc. i have a monthly contract (the £10 a month thing with unlimited calls, texts & data) but just want to double check whether it’s going to cost me to call. thanks:)
Numbers prefixed 03 are landline numbers, exactly the same as 01 & 02 prefixes.
If your plan includes calls to landlines, that means any number beginning 01, 02 or 03
i don’t rly know what that means tho. i dont rly understand all this stuff. i just need someone to tell me yes its free or no it’s not and costs x amount.
Christopher_G
Hi @ccapybaraa
Yes, as @bristolian said, it's classed as a normal landline and is included with any of our plans that give you a call allowance.
so i can call for free?
Ali_A
@ccapybaraa
0300 is not a "Freephone" number in the same way that 0800 is free, but you may be able to call the 0300 number without cost depending on your calling plan.
Like @bristolian has said- calling any number that starts 03, is the same cost as calling any number that starts 01 or 02.
So, to answer your question- if you can normally call numbers that start 01 and 02 (for example Manchester 0161 or London 0207) for free, then yes, you can call the 0300 number for free too.
You can find out more information at Costs to call non-geographic numbers | EE
Ali
