on 23-04-2025 08:46 PM
Where can I get a copy of the agreement I entered into on an upgrade/leaving phone call? I agreed terms on a share screen during g the call. Thanks for any help
Solved! Go to Solution.
on 23-04-2025 10:09 PM
EE's standard T&Cs are available at https://ee.co.uk/help/terms-and-conditions , if that's what you're looking for
on 23-04-2025 09:05 PM
You would have had the opportunity to download the documents during the session as each document was completed and showed a Download button.
You may still be able to access the link.
Otherwise you will likely need to contact Customer Services if you want to confirm the deal that you got.
