Symbols !?! What do they mean
broadbandcat
Hi.. I’m looking to upgrade but what do the symbols mean?? I’ve worked out the A in a box means add on, but what do the other ‘clocks’ mean ???
6 REPLIES 6
broadbandcat
Can you give a link to a page with these symbols on? Or screenshot them?
broadbandcat
 Hi.. does anyone know what these ‘clock like’ symbols mean ?  It’s not clear even if you  go into individual plans .  I feel  a link is needed to info explaining  what these symbols represent. 🙂
James_B
EE Community Manager
Hi @broadbandcat,
It's an indicator of the mobile data speeds you'll get on the plan.
If it's an essentials plan, you'll get a maximum of 100Mbps. If you select a All Rounder plan, you should see the 'full speed' icon.
Hope this helps.
broadbandcat
Thanks James. Is there a key anywhere ?
Christopher_G
I can't see a similar page on my iPhone, @broadbandcat. Is there a description of what each plan includes? Could you send me a link to the page please?
