24-07-2026 03:10 AM
24-07-2026 08:21 AM
@Kathleenpark68 On the EE app it’s under manage and then select billing. You should see the start and end date you can then work out how long you have left in the contract and what you pay for the remainder of the term.
24-07-2026 08:21 AM
24-07-2026 09:18 AM
In the subject line of your post, you've mentioned "paying bill together" - this may or may not be significant....
If you are on one of EE's traditional contracts, these have one single monthly payment covering everything - airtime, allowance, and device repayments. There is no concept of separating out any individual element. It's at the end of minimum-term where you can move to SIM-only if you wish.
If you are on a FlexPay plan where you pay separately for airtime & device, then follow Chris_B's post above.
24-07-2026 09:34 AM
@Kathleenpark68 : Text INFO to 85075 to find out your Early Termination Fees. It will basically be months left x monthly charge - 4%.
If you have more than 1 number on your MyEE a/c you can't use text to 65075 to get your PAC but will need to call CS for it.
