on 23-06-2024 08:54 PM
Hello,
I have a phone plan that is due to end later this year. I have an option to early upgrade, which I know would involve sending my current phone back before moving to another contract.
I want to know, if I was to see this current commitment period to the end, will I have an option to keep my phone then upgrade to a new mobile and set up a sim plan on the current phone I have got.
I want to use this phone as my work phone on a sim only plan whilst enjoying a new phone for personal use.
Solved! Go to Solution.
on 23-06-2024 09:09 PM
Once you are outside of the minimum term, you are free to keep your existing phone if you choose to upgrade.
You can always add another SIM-only plan to your existing account (which normally gets a multi-line discount) and use that SIM in whatever phone you like.
