Charge to bill
dylan415
Valued Contributor
Valued Contributor
Ever since the EE app update. My charge to bill subscriptions have failed and will not go through. It has rejected any charge to bill payments. Is anyone else having this problem?
dylan415
Valued Contributor
Valued Contributor
Just to let anyone know. This problem can be solved by re-downloading My EE app and going through the new set up!
6 REPLIES 6
Alex_M
Star Contributor
Star Contributor
Hi @dylan415 ,
There is a limit of £40 per transaction and £240 per line per month. Have you exceeded this?
Also, check that charge to bill is not barred by texting UNBAR to 150.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
dylan415
Valued Contributor
Valued Contributor
Thanks for the reply. After texting unbar to 150 I got the text back.
“We're really sorry but as you have a multi-line account and we can't confirm you're the account holder, we're unable to remove the third party bar for you
Please contact customer services on 150.”
I’ve used these services for the best part of 4 years. Very unsure how this has happened.
dylan415
Valued Contributor
Valued Contributor
Alex_M
Star Contributor
Star Contributor
Ah excellent! Glad you got it sorted.
SUBHYY__
everytime i try to add my number to apple phone bill it just says unable to send please try again
Katie_J
Good morning @SUBHYY__.
Thanks for coming here.
Are you aware if you have a bar on your account that would be stopping any charge to mobile actions?
Have you tried texting UNBAR to 150?
Katie
