Changing direct debit
Morrison55
Think someone should finally point this out cause it’s seriously starting to annoy me, ee says if you want to change your direct debit you need to click the top right button and press options that aren’t even there…. 
IMG_4557.jpegas you can see there’s no option whatsoever for neither broadband or direct debit. 
IMG_4558.jpegnow here I’ve pressed the “middle button” for accessing the bills and payments unlike the top right that we falsely states. And even at that I still have no option for changing a direct debit.
I wonder how many people have ruined there credit history due to ee not updating there help forms after app updates.
Linzi_H
Hi @Morrison55
Welcome to the Community.
We have step by step instructions on our help page 👉 Set Up or Change Your Direct Debit which gives the correct guidance on how to do this.
Can I just check you are doing this on your desktop browser as detailed in your screenshot?
If you're still having trouble, please try another browser or device. Our team can also help if you contact them directly.
Thanks so much,
Linzi
Linzi_H
Hi @Morrison55
Thanks so much,
Linzi
I’ve tried both desktop and mobile versions. Laptop mobile even went the extra mile to use the desktop version on my mobile and nothing.
At the end on the day the only real solution is to phone Ee and do it it that way but needless to say that shouldn’t have to be the only solution especially from the “best network provider in the uk” including the most expensive.
~Connor
Alex_H
@Morrison55 You definitely should be able to change your direct debit account via the website. Once you click Bills and Payments and are on the billing page, you should see a summary of your last bill.
But then if you scroll to the bottom of the page, under Your Account there should be 4 boxes, Make a payment, Payment history, Manage Direct Debit and Get more add-ons. Then obviously Manage Direct Debit is the one for changing your Direct Debit details.
Do you have this option if you double check the Billing and Payments section of the website? If not what can you see there?
Alex
