Change my data plan
Mandy1025
Hi, I am currently outside the UK, therefore I would like to change my data plan to pay as you go, is that mean I pay for how many data I used? And how would I contact ee’s support for the changes as I cannot make calls now, the ee app is also not working. Thank you so much.
Are you outside your min. term now? If not, you'll need to pay Early Termination Charges on your contract.
Follow How Do I Upgrade from Pay As You Go? to switch from PAYG to contract. Your existing PAYG credit will be carried over as credit towards your future bills. You keep your existing SIM & no. The plan on it is just switched to contract.
However if you move it to PAYG while abroad you can't use it until you return to UK. EE PAYG SIMs need 1st activating on EE's home UK network before they can be used abroad.
