on 09-07-2025 09:04 AM
If I were to take out a handset on a 36m Flex Plan with an airtime discount will those discounts apply after the 24m airtime contract has ended? Just wondering if my bill is going to go up or will I continue paying the same amount.
Solved! Go to Solution.
09-07-2025 11:36 AM - edited 09-07-2025 11:37 AM
Hi @TimmyCee.
Thanks for coming here.
The discount will end after the 24 months as this is an airtime discount not a handset discount.
You will have the option to move to a SIM only plan after the 24 months, this will reduce the amount you are paying.
Katie
Hi @TimmyCee.
Katie
