+1519
mckd21
When did EE decide that +1519 (Ontario) became part of the US for billing information purposes? Does not affect billings at the moment but could do in the future.
001519xxxxxxx
USA (from CAN)
Peter_W
Good morning @mckd21, thanks for bringing this to our attention!
Welcome to the EE Community too 😊
Where is it you're seeing this charge listed as to the USA, and are you making this call from within the UK, or whilst roaming in Canada?
Peter
I am fairly certain it started last month; looking at the call list for the September billing there is no entry under the place column for any international calls; in the listing for calls post Oct 9th - billing date - it is showing for both calls made from the UK and also from Canada when I was roaming during the month.
Duncan
Leanne_T
Morning @mckd21
Thanks for coming back to us.
I would suggest getting in touch with our mobile guides, they can check the bills for you and raise this to the relevant team to be investigated if needed.
Thanks.
Leanne,
