04-03-2022 10:34 PM
Is the password I use to log in to EE the same one I need to connect wifi to my iphone ?
04-03-2022 11:02 PM
@alan120 No. Your EE account password has no relevance to Wi-Fi passwords. Every router that allows you to join the Wi-Fi signal of that router has its own password, this is usually printed on the router in question.
05-03-2022 01:25 AM
Our online life is littered with diff pwds we need to have. These are just 2 of them!
05-03-2022 05:04 AM
Thanks for reply, As you may have guessed I'm new to all this, not sure what a router is or how to find it and it's password, Hope it's simply to do, can you help ?, Alan
05-03-2022 05:34 AM
@alan120 : The router is the box with flashing lights providing WiFi within your home. You should find its WiFi password written on a label stuck to it.
Do you have Broadband from EE?
05-03-2022 11:54 AM
Thanks for your reply, I have Virgin Media on my pc, and that's the only wifi I have managed to connect to my iphone. The reason I got this phone is to fill in plf form when on holiday in Spain. I assume Virgin wifi would not be available in Spain. That's why I'm looking for alternative provider, My phone has a ee sim card pay as you go. EE has appeared on phone settings as a wifi alternative but is asking for a password that I have no idea how to get. Somebody has mentioned a site or app called Keychain. any advise would be great. Alan
05-03-2022 01:25 PM - edited 05-03-2022 01:26 PM
I don't understand how you can have Virgin Media on a PC. Have you bought Broadband from Virgin Media? Have you bought Broadband from EE?
Describe your complete set-up, not just your devices. Do you have a socket on the wall that you plug a cable into? Does that cable go to a box with flashing lights? If so, what does a label on it give its name & model no.? Post an image of that box.
05-03-2022 02:02 PM
my set up is with virgin broadband on pc. I have nothing but a sim card from EE for my iphone. my problem is nothing to do with pc at all. it's about getting wifi on my phone. I'm being asked for a password from various suppliers and have no idea how to find one
05-03-2022 02:05 PM
I don't understand you. How can you have Virgin Media BB on a PC? I can't help you unless you answer all my previous questions.
05-03-2022 02:11 PM
as I said my problem is nothing to do with computer, It's only about the iPhone
