ssid and public sharing help
robbyj
Valued Contributor
Valued Contributor
HI .
is there a way to turn off the public wifi sharing on the ee hub ? .
it takes me to the bt website when i click on it and then i cant/dont have a bt account.
also
is there a way to stop/hide my wifi signal so nobody can see it being displayed .
thank in advance for any help or support
10 REPLIES 10
@robbyj : What EE router do you have (read label or post a pix)?
robbyj
Valued Contributor
Valued Contributor
it’s the black EE smart hub.
Which Smart Hub (post a pix)? There are a few.
robbyj
Valued Contributor
Valued Contributor
smart hub SH20A
That EE Smart Hub (2023) is a clone of the BT SH2 which has the EE WiFi bands enabled. There was a way to unsubscribing from them on BT but I don't know of any on EE.
robbyj
Valued Contributor
Valued Contributor
Hi, when I tried to stop the public share, it takes you to bt and crate an account.
which I don’t have.
Community Hero
Community Hero
@robbyj Are you able to see anything via the web manager interface, http://192.168.1.254 and more than likely in advanced wireless settings. This below is what you want to see will be in the advanced Technical log and have linked the post.
Public Wi-fi status:Not active
Switch from BT to EE unmitigated disaster - Page 2 - The EE Community
@JimM11 : Aren't you really trying to point to Re: Switch from BT to EE unmitigated disaster - The EE Community . You should be using Permalinks.
I told you before there is no point & is confusing in posting particular pages of a thread. We'll all have diff page layouts.
@XRaySpeX The link takes you direct to the page info required.
