on 04-02-2024 06:21 PM
hi, trying to connect Brother Printer to my dell laptop via our EE router at home, both printer and laptop connect to the router and i can print direct from my phone to the printer over wifi but cannot get the laptop and printer to find each other. The installation guide for the printer suggests I need to try turning of the 'privacy separator function' on the router. Been into the router settings and cannot obviously see anything, anyone else had this problem, any ideas much appreciate.
thanks very much
Angus
on 04-02-2024 07:11 PM
@angus8 assuming your Laptop is running Windows, have made sure the router network is set to private, not public?
Also are you able to connect to the printer using the ip address?
on 08-08-2024 11:11 AM
Hi. I too am having trouble connecting a brother printer by wifi. Our by hub 6 has just been swapped for an EE smart hub 32B. No problem before change.
Printer is visible on router hub manager showing its MAC address. IPrint&Scan initially appears ok then after a few seconds says it “cannot connect “. Local network is enabled but a Privacy Separator option isn’t obvious.
Any ideas please?
on 08-08-2024 11:28 AM
@Stairfield see my previous reply.
I am not aware of a privacy seperator option on EE routers, it is usualy a Windows private network setting.
on 08-08-2024 01:37 PM
This is also called "IP Separation". It is where you can have separate WLANs on diff subnets, e.g. 192.168.1.x & 192.168.2.x, that cannot interfere with each other. It was last seen on the old EE BrightBoxes & is also used by Guest networks.
Having said that I can't see how it affects connecting printers.
